![Color-Coding Added to Brushes for Stainless Steel Color-coding Allows for Easy Identification of Product, Even During Operation](/sites/default/files/styles/product_image/public/product_images/SS-CC-Group-2020.jpg?itok=0yRFqreu)
Weiler Abrasives, a leading provider of abrasives, power brushes and maintenance products for surface conditioning, has introduced color-coding on its most popular brushes for stainless steel. The color-coding helps stop cross-contamination in operations working with both carbon and stainless steel by making it easy to identify the correct wire brush.
The color-coding is a visual change to an existing product line — there will be no change to the performance of the stainless steel offering. Part numbers and pricing will also remain the same. The offering includes:
- Roughneck® Max Stringer Bead Wheel
- Wolverine® Stringer Bead Wheel
- Standard Twist Wheel with Nut
- Knot Wire Cup Brush
- Knot Wire End Brushes
- Crimped Wire End Brushes
Type 316 stainless steel brushes and degreased brushes are available by special order.
