Cube evo Tape Finishing Machine
Precision machining of wave-shaped components to reduce roughness and friction as well as for structuring and increasing the functional surfaces' contact area can now be carried out even more efficiently: The new tape finishing machine Cube evo for machining shafts, bearings and sealing seats is available from Thielenhaus Superfinish Innovation as a freely programmable unit and is designed to meet future Industry 4.0 standards.
The automatic loading technology reduces the machine's non-productive time and loading processes to an absolute minimum. With its quickly adjustable tape-finish units, the modular construction guarantees flexible, cost-neutral configuration for the most varied workpieces. A program with all the parameters required for the machining process can be stored and loaded for every workpiece that needs to be machined.
