Datron neo Compact CNC Milling Machine
DATRON Dynamics Inc. offers the DATRON neo compact CNC milling machine – the latest addition to the company's line of high-speed machining systems. Designed from the ground up to deliver a productive, in-office machining solution that improves and accelerates today's engineering workflow, the DATRON neo reportedly offers simple, clean operation and easy post-processing.
July 14, 2016
DATRON Dynamics Inc. offers the DATRON neo compact CNC milling machine – the latest addition to the company's line of high-speed machining systems. Designed from the ground up to deliver a productive, in-office machining solution that improves and accelerates today's engineering workflow, the DATRON neo reportedly offers simple, clean operation and easy post-processing. The affordable-yet-powerful neo enables design professionals to create precision models, prototypes and 3D metal parts without leaving the workplace.
With its intuitive operation terminal featuring DATRON's own "next" software, this compact milling machine appeals to machining beginners. The neo combines an interior camera and a multifunction touch screen interface for intuitive operation. The neo's integrated camera and 3D touch probe is designed to eliminate the time-consuming task of setting up jobs by using automatic recognition of the workpiece location which is drawn by the operator directly onto the touch screen. The interface quickly guides users through the milling process much like a smartphone or tablet app. Beginners benefit from the simple user interface and graphics.
"The DATRON neo's compact design and friendly interface resemble that of a 3D printer," said Robert Murphy, vice president of DATRON Dynamics. "The ergonomic design of the machine allows operators to load a workpiece from a position above the machining table while the height and angle of the workpiece is automatically setup at the operating terminal. The clean design and innovative enclosure give the operator a perfect view of and easy access to the machining area, which is quite ample in relation to the machine's very small footprint. In fact, the machine fits through a standard doorway and can be easily installed within a few hours."
Ideal for rapid tooling, design communication, and short-run manufacturing the DATRON neo is capable of milling a variety of materials up to 20" x 16.5" x 9" in size with its robust 40,000-rpm spindle and 24-station toolchanger/" data-glossary-id="142091" data-glossary-teaser="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" title="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" aria-label="Glossary: toolchanger/" data-glossary-id="142091" data-glossary-teaser="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" title="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" aria-label="Glossary: automatic toolchanger">automatic toolchanger">automatic toolchanger.
"The DATRON neo brings easy-to-use, professional quality high-speed milling capabilities into any workspace, at an exceptional price" said Bill King, president of DATRON Dynamics. "We are thrilled to offer this powerful new product to help our wide range of customers innovate faster and mill perfect quality parts."
  • automatic toolchanger
  • toolchanger
