![](/sites/default/files/styles/product_image/public/product_images/DM-MDMa.jpg?itok=C8ZvQLuT)
The RobbJack says its DM/MDM series with new carbide and coating combination, eliminates or reduces the need for polishing, reduces wear by 909 percent, holds tighter tolerances and lasts 450 percent longer than comparable carbides and coatings designed for hard metal applications. The 2-flute endmill allows faster feeds rates without chip packing, plus complete 3-axis capability.
- endmill
endmill
- polishing
polishing
