Eldorado KM75-48 3-axis Gundrilling Machine
The Eldorado KM75-48 is a 3-axis gundrilling machine used to manufacture products like transmission shafts, manifolds and mold matrices. The machine includes updated Beckhoff controls with G-code programming, which provides enhanced flexibility.
June 20, 2017
The Eldorado KM75-48 is a 3-axis gundrilling machine used to manufacture products like transmission shafts, manifolds and mold matrices. The machine includes updated Beckhoff controls with G-code programming, which provides enhanced flexibility. Complex gundrilling operations can be performed with a single fixturing setup.
The KM75-48 features a "knee" fixture table to provide 3-axis CNC gundrilling capability. Drill capacity is 0.078 to 0.75 inches (1.98 to 19.1 mm). Drill slide travel in the Z-axis is 48 inches (1219 mm), with table travel of 24 inches (610 mm) in the X-axis and 12 inches (305 mm) in the Y-axis.
  • G-code programming
    Programs written to operate NC machines with control systems that comply with the ANSI/EIA RS-274-D-1980 Standard. A program consists of a series of data blocks, each of which is t…
  • gundrilling
    Drilling process using a self-guiding tool to produce deep, precise holes. High-pressure coolant is fed to the cutting area, usually through the gundrill’s shank.
