FSP-80V Vertical Machining Center
Vertical 5-Axis machining centers have traditionally come with high price tags. Enter the FSP-80V from SNK America Inc.
July 1, 2015
Vertical 5-Axis machining centers have traditionally come with high price tags. Enter the FSP-80V from SNK America Inc. This compact machine is a viable alternative for a variety of industries requiring complex simultaneous 5-Axis contouring of difficult-to-cut materials. It's the preferred choice of machining professionals in a wide range of industries.
The FSP-80V incorporates all of the design and construction features required for the most demanding machining operations. The super-rigid box-frame spindle head houses a dual face spindle driven by a powerful 30HP motor that generates 1,407 Nm of torque. The A and B rotary axes employ a highly rigid double-pinion drive system that ensures stable, continuous 5-axis machining even under the most demanding loads. These features enable the FSP-80V to deliver the consistent, superb accuracies that vertical style machines are renowned for, without the high price.
Table size (W x L) is 31.5"x 78.7" with a maximum table load capacity of 8,800 lbs. Turcite slide ways ensure accurate machining of difficult-to-cut materials by greatly reducing cutting vibration. Travels (X, Y, Z) are 90.5" x 33.4" x 27.5". Spindle swivels (A, B) are ±30Ì¢åÅå¡.
The FSP-80V employs a Fanuc 31i-A5 CNC loaded with control features that simplify even the most complex contouring operations while delivering superb workpiece finishes.
Chip conveyors at both sides of the table ensure efficient chip evacuation. A 40 tool high efficiency ATC system (60, 80 optional) shortens cycle times for increased production.
Other optional features include air blow device, through spindle coolant, large capacity coolant tanks, splash guard and spindle overload prevention function.
  • machining center
