KAAST Machine Tools Inc. announces a new fully automatic NC cold saw for its line of circular saws. The HCS features a rigid design and sophisticated antivibration features, resulting in a cut that is fast, precise, efficient and clean.
The HCS is fast at up to 500 cuts/hour for 2.75” bars, and 400 cuts/hour for 24” clean-cut lengths. The automatic material diameter sensing ensures the fastest cycle times. The thin-kerf blade design (0.079”) keeps waste at a minimum all while increasing efficiency and productivity.
The design of the HCS also includes a top vice, which keeps the material clamped allowing bundle cutting for increased throughput. The bar loading magazine can hold 13 pieces of 2.75” x 20” bar with the option to upgrade capacity. The electromagnetic brake and gear transmission are designed to decrease noise, vibration and power consumption. All result in an increase in blade life and cut quality.
Other standard features for the HCS include a NC Control with 7” touchscreen, trim and remnant sorting, fast bar feed (944”/min), and saw blade feed by AC servomotor and ballscrew.
- feed
- numerical control ( NC)
- sawing machine ( saw)
