FXC Series Solid-Carbid Drills
Precision Cutting Tools' FXC Series, solid-carbide, straight-flute drills are engineered for drilling aluminum alloys and gray cast iron.
March 1, 2015
Precision Cutting Tools' FXC Series, solid-carbide, straight-flute drills are engineered for drilling aluminum alloys and gray cast iron. The drills are ideal for the automotive and aerospace industries and for operations that require tight-tolerance holes, according to the company.
The tools feature a total of four margins for increased stability and accuracy. The drills can achieve higher speeds and feeds than standard twist drills, reducing cycle times.
In addition, the combination of coolant-hole geometry and a 130º point enables efficient chip evacuation resulting in a smooth surface finish on the part, the company says. All FXC drills are PVD coated with ZircoPlus for a longer tool life. The drills are made-to-order within a 5-7 day lead time and are available in sizes ranging from 5 to 16 diameters deep.
  • aluminum alloys
    Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wro…
