H330 Series Endmill
The H330 Series is engineered exclusively for high-speed milling of Aluminum applications.
The H330 Series from Precision Cutting Tools Inc. is engineered exclusively for high-speed milling of Aluminum applications. With the inclusion of internal coolant holes, this helps to cool the cutting edge of the end mill and to help with chip evacuation. Its unique geometry allows it to run at maximum spindle speed and power; it can achieve RPMs as high as 33,000 on a 1″ diameter.
