Tungaloy’s TungMeister: High-Efficiency Exchangeable Head End Mill Series
Experience over 13,000 head and shank combinations for your endmilling operations with Tungaloy's TungMeister. Maximize productivity with 45 different geometries of indexable heads paired with steel, carbide, or tungsten shanks.
March 31, 2025
Experience over 13,000 head and shank combinations for your endmilling operations with Tungaloy's TungMeister. Choose from a wide range of exchangeable heads, including square, face milling, high-feed milling, ball, radius, barrel, slotting, threading, chamfering, and more! TungMeister increases productivity by up to 90% compared to a solid endmill, with a simplified setup where only the head is indexed. Precision threading ensures high accuracy and repeatability by maintaining full contact with both the taper and face. Choose from steel, carbide, or tungsten shanks for the ideal combination. Maximize your productivity today with Tungaloy's TungMeister!
  • chamfering
  • endmilling
    Operation in which the cutter is mounted on the machine’s spindle rather than on an arbor. Commonly associated with facing operations on a milling machine.
