High Feed 2
High Feed 2
The new High Feed 2 line of small diameter high feed milling tools from Seco Tools focuses on bringing high levels of productivity and reliability to modern CNC machines.
December 12, 2011
The new High Feed 2 line of small diameter high feed milling tools from Seco Tools focuses on bringing high levels of productivity and reliability to modern CNC machines. Offering high feed rates and small depths of cut, High Feed 2 cutters can handle a wide variety of applications, including pocketing, ramping, helical interpolation, facing, contouring, slotting and plunging. Cutting diameters range from .625" to 1.25".
The line includes a comprehensive range of PVD and CVD insert grades for hard steels up to 62 HRC and a wide variety of chip groove and flat geometries to effectively tackle several different types of materials, including superalloys. The chip groove geometries also allow for soft cutting in steel, stainless steel and other gummy materials.
High Feed 2 cutters achieve maximum removal rates through a combination of strength and number of teeth versus diameter. A close pitch allows very fast feed rates and stable cutting performance, even in in interrupted cuts. Furthermore, the well-balanced design of the cutter body and inserts enables free chip flow in copy milling, particularly when using toolholders with long overhangs. The High Feed 2 line also provides higher security through an optimized screw and torx socket size, a maximized insert cross section and an outside radius to prevent chipping.
  • interpolation
  • superalloys
