HR-3030 Horizonal Rotary Table
Ganro Industrial Corp. has made significant specification improvements to its horizontal rotary table series including the new HR-3030, which offers a new larger size table top and is available from CNC Indexing & Feeding Technologies.
January 13, 2013
The new HR-3030 CNC horizontal rotary table has a table top dimension of 3000mm (118.11"), 3905mm (153.75") table swing diameter, minimum indexing increments of 0.001 degrees, and a maximum work load capacity of 50,000 kg. or 110,230 lbs.
Changes to each of the current horizontal CNC rotary tables include upgrades to more powerful servo motors and stronger clamping torque with a newly designed hydraulic braking system. Also improved are work load capacities and additional built-in net weight for rigidity.
The HR Series is available with table tops ranging from 400mm (15.74") to 3000mm (118.11") square. Ganro's horizontal CNC rotary tables can be used in various areas of manufacturing but are ideal for horizontal boring mill applications. The HR Series design can be used as a full rotating axis incorporated into a machine's control or as an indexer with Ganro's M-Mate AC servo controller. They are designed for horizontal mounting only and offer high weight capacities for large workpieces. The HR Series rotary tables use a hydraulic brake system to insure rigid clamping during machining.
All Ganro horizontal CNC rotary tables and indexers use Ganro's core technology of a double lead worm shaft and worm wheel system for high precision and reduced backlash. Ganro rotary tables are assembled using cross cylindrical roller bearings with high rotation accuracy capable of bearing heavy loads in every direction.
