Live Tools for CNC Lathes
Koma Precision Inc. now offers live tools for CNC lathes from the Italian manufacturer Alberti, for Doosan, Feeler, Hyundia Wia, and Samsung Machine Tools.
Koma Precision Inc. now offers live tools for CNC lathes from the Italian manufacturer Alberti, for Doosan, Feeler, Hyundia Wia, and Samsung Machine Tools. Designed and manufactured to the OEM specifications, Alberti live tools enhance the performance of CNC lathes. Alberti live tool housings are machined from solid blocks of spheroidal cast iron to achieve tight tolerances. All bevel gears used are spiral Gleason gears made from aerospace/military grade steel. Precision ground spindle bearings and high performance seals result in high accuracy, rigidity, stability and durability in turning operations.
Currently, Koma Precision live tool line accommodates Doosan's Puma machines, Feeler's HT's and FT's machines, Hyundai Wia's L230, L300, L400, LV500, L600, L700, LV800, LF1600, LF1800, LF2000, LF2500, and LV1100 machines, and Samsung's SL-20, SL-25, SL-35, SL-45, and SL-65.
Along with live tools for Doosan, Feeler, Hyundia Wia, and Samsung Machine Tools lathes, Koma Precision stocks a range of standardized live tools for Okuma, Mori Seiki, Nakamura-Tome, and other major builders. Koma Precision live tool offering includes high-speed tooling, high pressure thru coolant, axial tools, radial tools, dual output radial tools and universal tools. Straight and offset units, modular quick-change systems and tapping quick-change holders are also available. In addition to Alberti live tooling; Koma Precision carries a range of precision Alberti Angle Heads for machining centers.
"Koma Precision Inc. and Alberti share a commitment to providing quality products that maximize the performance of machine centers," stated John Arnestad, regional sales manager, Koma Precision. "Koma's expert staff draws upon years of experience to help you choose the best live tools for your job. The better you are at choosing the right tools, the more efficient your process becomes."
