LoadAssistant Robotic System
HALTER's LoadAssistant is a robotic system for loading workpieces into CNC machines. It is a universal for both CNC lathes and machining centers, with a rotating loading system that can handle a large range of workpieces quickly. It assists in increasing production output and improves profit immediately, even when dealing with small batches, according to the company.
The LoadAssistant was designed to minimize setup time, enabling users to automate even small batch sizes. Total setup time is less than 5 minutes.
No robotics experience is required to operate the system's SmartControl. No robot programming is necessary. Just enter the dimensions of the product to be loaded. The machine is accessible by the operator at all times. It is equipped with a floor scanner to slow down and stop the robot arm.
Optimal gripper system is quick and easy to adjust. A two- or three-finger gripper is available. The program is ready in just a few steps.
Compact all-in-one design:
No additional components, fences or cables necessary
Rotating system allows filling from the backside
Minimal usage of floor space, including the safety zone
FANUC 6-axis robot arm:
Maximum load capacity of robot arm: 22 lbs. (10 kg), 44 lbs. (20 kg) or 77 lbs. (35 kg)
Suitable for industrial environments, high standards regarding stability and accuracy
