Metal Dust Collector Stand
The new JET metal dust collector stand is an ideal metalworking shop addition that captures abrasive dust, chips and other debris with a filter efficiency of 90 percent at 50 microns. The free-standing dust collector's turbo fan design provides maximum air movement of 472 CFM for effective metal dust collection.
The JET Metal Dust Collection Stand accommodates all bench grinders and with the optional universal Adapter Plate, most belt/disc sander brands (#414830). The durable stand is constructed of heavy-duty, 16-gauge steel. Its non-sparking fan blade and motor housing safely manages overheating and helps prevent fire during chip and metal dust collection. Chips and dust are captured in a removable metal drawer that's easy to empty. The stand's high temperature, high performance filters are replaceable.
The dust collector is powered by a ½ HP motor that operates on 115V and a 20-amp circuit. There are two, 3-in. inlets to accommodate dust collection hoses. Maximum hose velocity is 3,465 (SFPM) with a static pressure (Wc) of 748. Maximum static pressure (Wc) is 2,440. Two 115V outlets on the side of the stand provide power needs for bench grinders, belt/disc sanders and an auxiliary goose neck lamp. The stand also is equipped with two removable water pots for cooling parts and tools.
Other features include a large on/off paddle switch with removable magnetic safety key to prevent unauthorized use and four adjustable, leveling pads.
