A portable pneumatic saw with a pipe trolley system for accurately square cutting ductile iron concrete lined pipe from 6" to 60" in diameter is available from ESCO Tool. The MILLHOG APS-438 Air Powered Saw and steel WrapTrack System attach to a pipe's circumference and feature an abrasive blade designed for cutting ductile iron concrete lined pipe. Producing square cuts with 1⁄8" accuracy, this fully portable saw mounts on a trolley equipped with four V-grooved steel wheels that glide along the steel WrapTrack system which can be sized exactly to fit the pipe OD.
Providing a perfectly square cut for subsequent welding or to assure a flush cut for couplings, the MILLHOG APS-438 Air Powered Saw and steel WrapTrack System is superior to guillotine saws and torches. This rigid pipe cutting system is suited for cutting stainless steels, Inconel, and other highly alloyed pipe without leaving a heat affected zone (HAZ).
The MILLHOG APS-438 Air Powered Saw sells for $5,395.00 and the WrapTrack is $450.00 up. Rentals are also available from $295.00 per week.
- abrasive
abrasive
- outer diameter ( OD)
- sawing machine ( saw)
- stainless steels
stainless steels
