Model 300 Mist Collector
The Model 300 mist collector filters the air on enclosed machinery to remove harmful oil mist and particulates from CNC machines, including milling and grinding processes. This unit offers a primary control solution by mounting to the machinery and filtering the mist at the source.
The mist collector can be used to not only filter oil mist but for coolant and water soluble mist as well. The filter chamber includes a pre-filter, carbon filter and a main filter (HEPA or ULPA). No exterior ducting is required for this unit.
  • coolant
  • gang cutting ( milling)
  • grinding
  • milling
