The Model MV-2L Swam-Blast Micro Sandblasters introduce a precise amount of finely graded abrasive powder into a controlled stream of compressed air through the abrasive pathway and out a manually or automatically positioned nozzle tip. Total process control can be achieved with independently adjustable powder flow control and air pressure regulation.
Powder flow can be adjusted on the fly. When detail is required, the powder flow is turned down to reduce the amount of the powder being metered into the abrasive/air pathway thus allowing the use of very small nozzle tips. For more aggressive requirements, the air pressure, powder flow and the nozzle tip diameter can be increased.
- Nozzle sizes and styles are available along with a variety of powder types and particle sizes.
- Interchangeable orifice plates are available to increase the range of powder types and sizes.
- Front and back panels unlatch to easily access components and carbide lined fittings throughout the abrasive/air pathway for routine maintenance.
- The powder tank is mounted to a hinged plate that allows it to tilt to the side and with the push of a button, the vibrator activates to simply walk the powder out for rapid powder changes.
The Model MV-2L is suitable for nozzles sizes from 0.014″ up to 0.060″.
- abrasive
abrasive
- lapping compound( powder)
- process control
process control
