MULTUS U Series Multitask CNC Lathes
Okuma America Corp. announces its new MULTUS U Series general-purpose multitasking CNC lathes, which are designed to reduce setup time, improve accuracy and keep non-cutting time to a minimum.
March 1, 2014
Okuma America Corp. announces its new MULTUS U Series general-purpose multitasking CNC lathes, which are designed to reduce setup time, improve accuracy and keep non-cutting time to a minimum. The series includes two machine sizes: the MULTUS U3000 and the MULTUS U4000. The MULTUS U Series lathes are equipped with a comprehensive package of Okuma's Intelligent Technologies (Thermo-Friendly Concept, Collision Avoidance System and Machining Navi) and a variety of efficiency features which make them "intelligent multitasking machines."
Built with Okuma's heavy-duty construction, the MULTUS U series CNC lathes provide a robust platform for long-term rigidity and accuracy. They are excellent for machining process-intensive parts, such as those in Aerospace, Oil/Energy, Medical and Construction, and provide a complete multitasking solution:
Flexible CNC machining from all directions — A highly rigid traveling column allows for powerful cutting along the entire Y-axis.
Extended specs for a variety of applications — 17 diverse variations in specs, including multiple bed lengths, optional sub-spindle (W-Axis) and optional lower turret, provide a specific solution that matches application requirements.
Maximum Milling or Turning Performance — For highly-efficient cutting of difficult-to-machine materials and a wide variety of CNC machining applications.
Thermo-Friendly Concept — Provides long, stable machining accuracy with thermo-static design and thermal deformation control technology.
Shorter Setup Time and Prevention of Collisions — The OSP-P300S control reduces keyboard operations by 50 percent and maximizes uptime with its Collision Avoidance System.
Machining Navi — Maximizes tool performance by choosing the optimal speed(s) at which the machine can avoid chatter.
Operator-Friendly Design — Easy tool loading from the machine front, improved spindle access for faster setup times, and smooth chip discharge for better chip flow.
