SPRING Technologies announces the worldwide launch of NCSIMUL CAM. This new product delivers agile CNC programming to streamline the current CAM process and enhances flexibility on the shop floor.
Fully integrated in the new unified NCSIMUL SOLUTIONS V10 platform (including NCSIMUL MACHINE, NCSIMUL TOOL, and NCSIMUL DNC), it embodies SPRING Technologies' response to today's issues in CNC machine programming: removing the typical organizational method of tool path generation (CAM), post-processing, G-code verification and simulation and streamlining the conventional CNC programming process.
According to the company, the primary benefits will be significant cost savings and optimal use of CNC machine because of the flexible programming capability. "This is a major new step forward for the company's product strategy and in the manufacturing industry," said Philippe Solignac, corporate marketing director for SPRING Technologies.
NCSIMUL CAM directly generates verified and optimized CNC programs, while factoring in the physical resources available on the shop floor, including tools, cutting conditions, kinematics and machine controllers.
With this new solution CAM data (APT neutral file/CL-data) and existing CNC programs can be used easily to generate a valid new CNC program in just a few clicks for another machine using different kinematics and controller. This will enable manufacturers to quickly adapt their existing programs to new resources when retrofitting a machine, buying a new one or when a machining process is repurposed. With a conventional CAM process (CAM-Post-Processor-Machining Simulation), this task could take hours, even days. With NCSIMUL CAM, these times are slashed to minutes.
Likewise, if the target machine initially planned for the CAM program is no longer available for maintenance reasons or is already being used to meet production, it will take just one click with NCSIMUL CAM to switch programming to another machine – whatever its complexity (3X to 5X, 5X to 4X…), the type of kinematics (tilting head to table-on-table for instance) or the type of controller (FANUC, Siemens, Heidenhain …).
Thanks to the integration of NCSIMUL Tool database, NCSIMUL CAM provides a direct access to 3D tool data and cutting conditions and automatically reconfigures the tool magazine.
This will provide manufacturers with the level of flexibility they need to achieve rapid switching of scheduled production from one CNC machine to another, making their production means fully flexible and agile, according to the company.
