Norton Winter Ironclad Wheels
Norton Winter Ironclad Wheels offer several additional benefits including reduced downtime due to longer wheel life which extends time between setups. There is less bluing of castings even towards the end of the wheel life. Promoting a cleaner, healthier work environment, the new wheels generate significantly less dust and odor compared with traditional bonded wheels.
July 23, 2020
Saint-Gobain Abrasives, one of the world's largest abrasives manufacturers, announced the introduction of its new patent-pending Norton Winter Ironclad™ Diamond Single Layer Superabrasive Wheels that achieve maximum material removal for increased productivity, especially when used in automated grinding cells. Featuring the strongest and most durable bond on the market, Ironclad wheels finish up to 50% more parts per wheel compared with electroplated wheels. Norton Winter Ironclad Wheels are a superior solution for ductile and grey cast iron applications such as fettling and snag grinding on casting gates, parting lines, sprues, and more.
"The advanced, high performance bond has up to 75% grain exposure, offering heat resistance and lubricity to achieve larger depths-of-cut and cooler cutting," said Andy Schoch, Product Manager for Single Layer Products, Norton│Saint-Gobain Abrasives. "The unique bond also reduces friction, allowing for lower grinding power. Norton Winter Ironclad Wheels provide significantly higher stock removal rates and a lower cost per part compared to other standard plated products." The new wheels produce more burr-free parts, minimizing secondary operations.
No wheel dressing is required and the rigid steel hub reduces vibration during CNC grinding. A known grinding wheel location facilitates easier programming, and a rigid steel hub reduces vibration resulting in consistent wheel dimensions and minimal wheel wear.
All Norton Winter Ironclad Wheels are made to order to meet precise requirements. The wheels are available in a variety of profile shapes and wheel sizes suitable for a range of grinding cast iron parts.
  • grinding wheel
