OptiRough Toolpath
OptiRough Toolpath
CNC Software Inc.'s OptiRough is a new technique designed to remove large amounts of material quickly using its successful dynamic milling motion.
CNC Software Inc.'s OptiRough is a new technique designed to remove large amounts of material quickly using its successful dynamic milling motion. Large, aggressive cuts are followed by fast, smaller up-cuts, safely delivering a fully roughed part faster than ever. Mastercam's new 3D surface high speed OptiRough toolpath supports cutters capable of machining very large depths of cut.
A single OptiRough toolpath can cut material in two directions: on step-downs (-Z) and step-ups (+Z). This highly efficient, bi-directional cutting strategy removes the maximum amount of material with the minimum of step-downs, significantly reducing cycle times.
"The beauty of OptiRough is that you don't need any special tooling to use it. It simply uses the tools you have now, but in a much more efficient way," says Gary Hargreaves, VP, Business Development.
