Ott-Jakob Power Drawbar
Advanced Machine & Engineering introduces the improved OTT-JAKOB brand power drawbar for toolholding.
May 1, 2015
Advantages of the OTT-JAKOB Power Drawbar include:
• Power off clamping
• Intensified spring force
• Compact design with minimal rotating mass
• No load on spindle bearings during tool change
• Low tool release force required
The cutting tool is held securely in the spindle taper with gripper fingers. These fingers are pulled into the taper with the spring pack of the power drawbar. The pull-in force is multiplied by the patented intensifying mechanism. The spring force applied to the clamping sleeve pushes the balls outward. The angle design of the clamping ring and cylinder shoulder increases the spring force 300 percent. The cam inside the spindle closes the gripper fingers and the tool is securely locked.
Loss or reduction in hydraulic pressure will not release the tool. The power off design requires pressure applied to the hydraulic piston and transmitted through the rod to push the clamping sleeve down. This unlocks the intensifying mechanism. After clearing the cam, the gripper fingers open and the face of the holder ejects the tool with a controlled stroke.
