Pramet Force AD Milling Cutter
Dormer Pramet says the Pramet Force AD milling cutter is revolutionizing end user productivity with its versatility. This universal shoulder milling cutter features a differential pitch to reduce vibration and system noise. Combine solid performance with the cutter's application with multiple materials and in harsh environmental conditions and users have the ideal universal shoulder milling product to fit their needs.
The body of the milling cutter is constructed of a new material specifically suited to machine a pocket for the insert after head treatment. The result in application is closer tolerances for higher accuracy. Designed to be corrosion resistant, the tool also provides increased strength at higher temperatures.
Other features of the Force AD resulting in increased productivity include:
High positive 27° geometry to reduce cutting forces
FA geometry specific to ISO "N" materials to reduce material sticking
Special surface finish for increased corrosion resistance, reduced wear and lower friction resistance
Polished inserts for high feed and differential pitch
