Precihole BTA Deep-Hole Drilling Machines
December 13, 2012
Zagar Inc. has introduced a new range of Precihole BTA Deep Hole Drilling Machines. BTA Drilling, also known as STS (Single Tube System) drilling provides holemaking in the (I.D.) range of 1.00'' to 12.00'' solid drilling, and 16.00'' counter-boring with lengths of up to 40 feet – far greater than a conventional gun drilling process.
The BTA process drills holes into the center of cylindrical parts, achieving high concentricity by rotating the cutting tool and feeding it into a counter-rotating part. The cutting tool is designed with carbide inserts and guide pads mounted to a toolholder drill tube and coolant is introduced at high pressure around the drill tube. This design allows the chips to be evacuated through the center of the drill and provides precise cutting efficiency. The coolant is then cleaned, cooled and recycled for maximum utilization.
Zagar/Precihole will be offering four models with spindle power of 22, 37, 71, and 115 kw. All machines are available with either FANUC or Siemens CNC controls. Also available are more economical BTA machines that hold the part stationary and feed the cutting tool. These are for applications where a high degree of concentricity is not required.
These BTA machines are designed for major parts production in industries such as defense, oil and gas, hydraulics, automotive, general engineering, heavy engineering, power generation, nuclear energy, steel manufacturing and off the road vehicles, to name a few.
  • coolant
  • feed
  • toolholder
    toolholder
Sponsored Content
