![Addition of More Than 30 Pressed-Geometry Carbide Inserts Pressed-Geometry Carbide Inserts](/sites/default/files/styles/product_image/public/product_images/new-insert-grades-CCMM-TCMT_RGB.jpg?itok=FcGltpsU)
BIG KAISER Precision Tooling is adding more than 30 pressed-geometry carbide inserts for its tools. The new insert design is the result of extensive research and testing.
The new grades and geometries offer:
- Improved chip control due to optimized chip breakers, even when boring gummy materials like low-carbon or stainless steel
- Improved coatings for increased speed and better wear resistance
- More positive cutting geometries to reduce cutting forces, chatter and vibration when used in deep-hole boring operations
- Longer tool life
- Up to 20% savings when compared to current grades
BIG KAISER offers a range of insert grades and geometries for rough and finish boring, grooving and precision cutting, including indexable inserts.
- boring
boring
- chatter
chatter
- grooving
grooving
- wear resistance
wear resistance
