Red Shark Tap
Red Shark Tap
When a large new vessel is put to sea, it usually is equipped with a tunnel thruster (or bow thruster), which acts as a side propeller system to allow for additional maneuverability of the ship at berth and on open sea. Using tunnel thrusters, captains have increased control and can turn around a ship on a dime, raising ship's efficiency.
July 24, 2017
Brunvoll AS is a global manufacturer of seaworthy motion systems with headquarters in the Norwegian Sea. The company has supplied more than 8,000 complete side propeller systems mounted on more than 5,000 different cruise ships, supply boats and navy vessels.
Brunvoll's offer consists of five different types of tunnel thrusters, where each variant is available in a variety of sizes with a diameter which varies between 3 to 10 feet and with one engine power of between 150 to 4,500 hp.
"In a normal year we deliver about 350 tunnel thrusters in different variants," says Roy Unhjem, machine tool maintenance lead at Brunvoll. "In addition to the standard variant, we have a tunnel thruster with extra shock absorption. It reduces sound and vibration and is mainly sold to cruise ships. The actual tunnel thrusters - besides software and control systems – are manufactured in three different materials. The outside of the tunnel which surrounds the propeller is made of steel sheets, cut, rolled and welded. The housing is cast iron. The rotor plug and propeller blade are case in an alloy of nickel, aluminum and bronze. In extreme cases, we have needed to produce components in acid-proof steel.
The machining of the propeller is conducted mostly unmanned and at night due to the fragile and brittle nature of the nickel-aluminum bronze alloy. This demands very well-functioning manufacturing processes and tools.
The new Dormer Red Shark is a threaded tap designed for use specifically with steel alloys. The versatility of the Red Shark tap allows for it to be used in different dimensions and at different torques, for example, for threading the propeller at the attachment to the rotor.
The Red Shark increases tapping ability and service life, providing users with reliability and tool economy at high cutting speeds. Brunvoll drove the Red Shark up to 164 feet/minute. It was assessed that optimal cutting in the nickel-aluminum bronze was at 115 feet/minute. To ensure optimal productivity and safety, the unmanned machines at night are lowered to the cutting speed of 82 feet/minute. In any of the speeds, the Red Shark took a bite out of tapping.
Besides the additional productivity of the Red Shark, it offers the flexible to be used with other materials other than just steel alloy.
  • cutting speed
