YG-1 SV-Point spade drill inserts provide longer tool life at higher spindle speeds and feeds than conventional spade drills.
SV-Point spade drill inserts offer exceptional performance in a wide range of applications and materials including steel, stainless steel and cast iron.
- H-Coating for high heat and wear resistance
- Sinusoidal thinning edge for smooth cutting and improved centering
- Positive rake angle for improved hole finish
- Low thrust force – excellent option for underpowered machines
Three material options:
- Super Cobalt (T15) — For improved tool life and performance over standard HSS inserts – size range: 9.5mm to 114.3mm
- Premium Cobalt (M48) — Extended tool life over T15 in harder materials – size range: 9.5mm to 114.3mm
- Carbide C5 (P40) — For longer tool life and faster speeds & feeds in rigid setups – size range: 9.5mm to 47.6mm
- centering
centering
1. Process of locating the center of a workpiece to be mounted on centers. 2. Process of mounting the workpiece concentric to the machine spindle. See centers.
- high-speed steels ( HSS)
- rake
rake
- spade drill
spade drill
Flat end-cutting tool used to produce holes ranging from about 1" to 6" in diameter. Spade drills consist of an interchangeable cutting blade and a toolholder that has a slot into which the blade fits. In horizontal applications, universal spade drills can achieve extreme depth-to-diameter ratios, but, in vertical applications, the tools are limited by poor chip evacuation.
- wear resistance
wear resistance
