TP530 Rotary Table
TP530 Rotary Table
Catering to the oil, gas and aerospace machining industries, Kitagawa-NorthTech offers the TP530, a new state-of-the-art rotary table with an extremely compact body.
January 13, 2013
Catering to the oil, gas and aerospace machining industries, Kitagawa-NorthTech offers the TP530, a new state-of-the-art rotary table with an extremely compact body. It has a 4x smaller footprint than conventional NCRTs, with 440 pounds less weight distribution. Even with a significantly smaller body and lower weight, the TP530 delivers a mega through-hole design at 13.6 inches, matching conventional NCRT's without exceeding table load limitations.
Unlike the larger 31.6 inch rotary tables, the TP530 features a low center height of 12.2 inches and high Z-axis clearance. This also provides a comfortable fit within most CNC machines, rather than purchasing a new machine to fit around the rotary table due to excessive size. This advanced mega through-hole model maintains accuracy, withstands heavy cutting conditions, and retains a high clamping force of 6100Nm/4,499 ft.-lbs. This rotary table is suited for machining large work pieces such as oil pipes.
  • through-hole
