TT02 Torque Tool Testers
Mark-10 Corp. has announced its Series TT02 torque tool testers for the accurate and reliable verification of applied torque values derived from torque screwdrivers, wrenches, and other small hand tools used on the factory floor and in other production environments.
November 13, 2013
Having an understanding of a tool's applied torque is important for ensuring product quality, safety and reliability. While fasteners can be inexpensive, an improperly tightened fastener can cause a host of operational problems, ranging from the minor, up to catastrophic failure. Attaching fasteners with appropriate amounts of torque prevents them from vibrating loose or, alternatively, from stripping threaded fasteners. Torque tools can also go out of calibration, particularly from ongoing daily use. By instituting a regular torque fastener tool performance verification program, manufacturers can better ensure product quality and performance.
Series TT02 torque tool testers capture peak torque values in both measurement directions at a rapid sampling rate of 7,000 Hz with +/-0.3 percent full scale accuracy. The Series TT02 also calculates first and second peaks for the measurement verification of click-type tools. Their universal 3/8" square receptacle accepts common bits and attachments. The Series TT02 also includes a range of productivity-enhancing features, including USB, RS-232, Mitutoyo, and analog outputs; automatic data output/zeroing/data storage upon tool slip or click; memory storage for up to 1,000 readings; and pass/fail indicators and outputs.
