Twincut CNC Tube Sawing Machine
BLM Group USA’s Twincut is a CNC tube sawing machine capable of cutting parts in two different lengths simultaneously. Equipped with an automatic feeder, bars are loaded and cut, and then finished parts are unloaded automatically for a continuous, high productivity operation. The double bar configuration more than doubles output, guaranteeing the lowest possible part cost. It’s robust, reliable and fully-automatic for extremely efficient, continuous, unmanned, saw cutting operations.
The Twincut is available in single or double bar configurations, and can cut bundles of round, square, rectangular and other shaped aluminum and steel tubes. It can handle material up to 3.15” in diameter (80 mm) for single bar applications or 1.77” in diameter (45 mm) for double bar applications, and maximum part lengths of 240” (6,090 mm).
To boost throughput, it also features three unloading positions to separate clean parts from scrap and chips without interrupting production. Two are dedicated to production parts — at the front and rear of the machine — to differentiate the cut lengths and to change out collection boxes. The third discharge location is dedicated to bar end scrap and chips, which are collected and removed from the cutting zone by powerful air jets.
After cutting, the part ends can be automatically wire brushed to remove any burr. Part length can also be measured and certified, and systematically collected in finished part containers, sorted by programmed shape and size.  An automatic washing system, entirely made of stainless steel and thermally insulated, is available for even more complete cleaning results.
  • burr
    burr
  • sawing
    sawing
  • sawing machine ( saw)
  • sawing machine ( saw)2
