VARIA Quick-Change Toolholder
VARIA toolholder/" data-glossary-id="141671" data-glossary-teaser="Cutter holder that permits rapid tool changes. Generally associated with automatic or semiautomatic machining operations. See toolholder." title="Cutter holder that permits rapid tool changes. Generally associated with automatic or semiautomatic machining operations. See toolholder." aria-label="Glossary: quick-change toolholder">Quick-Change Toolholder
Quick-change VARIA from ITI Tooling Co. Inc. is a fast, safe and flexible tool holding system that is used to reportedly improve the productivity of most modern CNC lathes.
June 1, 2015
Quick-change VARIA from ITI Tooling Co. Inc. is a fast, safe and flexible tool holding system that is used to reportedly improve the productivity of most modern CNC lathes. It will enable users to exchange most cutting tools and get a CNC lathe back into production in a short time.
The "highlight" of this system is that instead of replacing the tool by removing it together with the tool holder or live spindle unit, with Quick-Change VARIA, it's simply a small tool head and the cutting tool that is exchanged. The large tool holding fixtures and heavy spindle units stay on the lathe.
Plus, users exchange these tool heads in the minimum of time due to the patented single "rapid-clamp" screw device.
By using preset tool heads and with the single rapid-clamp screw device, experienced users frequently exchange tools within a few seconds. On many machines, the single clamp screw is set up to orient towards the operator when the machine stops, no need to reach into the machine among the many sharp cutting edges and chips to find the clamp screw, plus the patented clamp does not require any radial force to release it.
There's no need for operators to grasp onto any warn or broken tools while they are being unclamped. Now, they simply blow off the area, rotate the clamp screw 180° with the supplied "T" handled Allen wrench, this releases the existing tool head and bumps it forward slightly in the holder for easy removal.
Then a replacement pre-set tool head is inserted into the holder, the clamp screw rotated in the opposite direction pulls the tool head back against a datum surface and firmly locks into place, and the lathe is ready to continue.
Not only do the Quick-Change VARIA tool holding components register together accurately and form a rugged assembly, they are compact and offer an enhanced interference-free work zone on the lathe.
The interchangeable tool heads of the series: V3 (VDI 30) and V4 (VDI 40) can be used on a variety of different base units and tool spindles, offering almost limitless flexibility and added cost savings to the user.
Now, with the introduction of larger V5 (VDI 50) series, additional machines can also benefit from this simple, safe and cost-effective tool holding system.
Also available for BMT (base mount tooling) style turrets.
  • quick-change toolholder
  • toolholder
