Wallover Oil Co. introduces WS 8800 machining coolant. WS 8800 is a high-performance, chlorine-free coolant for machining and grinding of ferrous and nonferrous metals including stainless steel, titanium, cast aluminum alloys and cast iron. It is particularly effective for machining all alloys of aluminum.
Clear, blue WS 8800 is formulated with an advanced bioresistant additive technology to provide a high level of performance in controlling bacteria and fungus to eliminate odors. Tooling costs are reduced due to the extreme pressure lubrication that extends tool life.
In addition, WS 8800 extends sump life and reduces waste disposal costs. This long-lasting fluid makes it ideal for both central systems and individual sumps. Its nonsticky formulation protects against fouling valves and switches.
The nonfoaming characteristics of WS 8800 make it ideal for high pressure CNC machining. It offers excellent rust and corrosion protection for the inner workings of the machine tool and rejects tramp oil for easy skimming.
- alloys
alloys
- aluminum alloys
aluminum alloys
Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wrought compositions and casting compositions. Some compositions may contain up to 10 alloying elements, but only one or two are the main alloying elements, such as copper, manganese, silicon, magnesium, zinc or tin.
- coolant
- grinding
- tramp oil
tramp oil
