The first four-flute drill on the market!
The CERATIZIT WTX-HFDS solid carbide drill with Dragonskin coating achieves new levels of quality, hole tolerance, and positioning accuracy, with low burr formation while entering and exiting the hole. The core stability of the drill is retained with optimum cooling via four internal spiral coolant holes making the drilling process safe and effective.
The CERATIZIT WTX-HFDS solid carbide drill with Dragonskin coating achieves new levels of quality, hole tolerance, and positioning accuracy, with low burr formation while entering and exiting the hole. The core stability of the drill is retained with optimum cooling via four internal spiral coolant holes making the drilling process safe and effective. The pyramid geometry of the WTX-HFDS allows for higher speed rates and precise drilling performance and the cutting force is distributed to all four cutting edges, providing longer tool life and overall cost savings.
Learn more about the WTX-HFDS drill here.
n
