Sipping Into 2025: Vargus USA’s Tools to Boost Threading Performance and Productivity
Published Date
December 19, 2024 - 06:00:pm
Video player not loading? Click here to watch on Vimeo!
Join us for a special year-end episode of Bourbon With The Editor as we sit down with Ed Tichelaar, Michigan Application Engineer at Vargus USA, to explore the latest breakthroughs and innovations for 2025. From cutting-edge tools like the VT10 and its revolutionary substrate and coating technology to the debut of new helical and threading solutions, this conversation dives deep into how Vargus continues to push the boundaries of machining excellence.
Discover how their newest products, including V-MILL, V-DRILL, and broaching solutions, are transforming the industry and rapidly becoming the go-to choice for high-performance threading across materials. Stock levels, performance reports, and exclusive insights ensure this episode is packed with value for machinists, engineers, and manufacturing professionals alike.
Pour a glass and join us as we toast to innovation and gear up for a great 2025 with Vargus USA.
  • broaching
    broaching
    Operation in which a cutter progressively enlarges a slot or hole or shapes a workpiece exterior. Low teeth start the cut, intermediate teeth remove the majority of the material and high teeth finish the task. Broaching can be a one-step operation, as opposed to milling and slotting, which require repeated passes. Typically, however, broaching also involves multiple passes.
  • threading
    threading
Sponsored Content
