Video player not loading? Click here to watch on Vimeo!
Welcome to Bourbon with the Editor, hosted by Cutting Tool Engineering, featuring Vargus USA as our distinguished guest. Joining us are Joe Magee from Vargus and Dennis Spaeth, your host from CTE (Cutting Tool Engineering). This episode dives deep into Vargus’s latest triumph—the FS Line, an economical range of fully sintered inserts designed to revolutionize machining across diverse industries. Alongside our discussion on cutting-edge tooling innovations, we’ll also explore the finer things in life—like the exquisite Bourbon known as Blanton’s.
The FS Line boasts 62 essential profiles for both external and internal threading, ensuring unparalleled versatility across ISO Metric, American UN, Whitworth, NPT, BSPT, and API Round standards.
Key features include:
Versatility: Adaptable across multiple threading standards, indispensable for various machining needs.
Economical: Engineered for cost-effectiveness without compromising performance, ideal for widespread use across sectors.
Durability: Available in two robust grades—FSK (TiN coated) for steel and general applications, and FST (TiAlN coated) for stainless steel—ensuring enduring performance in challenging environments.
Compatibility: Designed to fit all standard thread turning holders, enhancing flexibility in machining operations.
Innovative Packaging: Featuring new 10-piece snap-off packaging for enhanced convenience in handling and storage, reflecting Vargus’s commitment to user-friendly solutions.
Advanced Tool Selection: Integrated into the VARGUS GENius™, the industry’s leading tool selector and CNC program generator, optimizing efficiency in tool selection and CNC programming.
Adding to the allure, we invite you to savor Blanton’s Bourbon—a refined choice known for its distinctive flavor profile, drawn from the heart of Kentucky’s Bourbon tradition. Renowned for its spicy character and rich complexity, Blanton’s Bourbon is the perfect complement to our discussion on precision and innovation in tooling technology.
This episode promises a captivating blend of engineering expertise and Bourbon appreciation, starting at 6 PM CDT on June 27th. Don’t miss out on this unique opportunity to explore the intersection of craftsmanship and cutting-edge technology with Vargus USA and Cutting Tool Engineering.
Explore FS Line Inserts at Vargus USA | View Product Release and Resources
Check out Vargus GENius Software! (Web/Desktop/Mobile)
Full Videos from Episode: Vargus Machining Tip 107: Best Type of Pass for Thread Turning Applications | Vargus Machining Tip 108: Recommended Thread Turning Infeed Method | Vargus GENius Tutorials - Session 3: Thread Turning
View/Download 2024 Vargus Promotions PDF or view below:
- threading
threading
- turning
