IMTS is the place to check your wish list
Author Michael Deren
September 01, 2016 - 03:15am
Yup, it’s that time! It’s kind of like Christmas ... except it happens only once every 2 years and lasts for 6 days. The trade show of trade shows—IMTS—is coming to Chicago’s McCormick Place.
From Sept. 12 to 17, attendees will have their pick of more than 15,000 machine tools, controls, tooling and other manufacturing technologies to see and touch. More than 2,000 exhibiting companies, representing every sector of the manufacturing industry, will be there. If you don’t see it at IMTS, you probably don’t need it.
Each of the 10 pavilions is geared toward specific technologies. They focus on abrasive machining, sawing and finishing; additive manufacturing; fabricating and lasers; gear generation; machine components, cleaning and environmental-related products; metalcutting; CAD/CAM and controls; EDMing; quality assurance-related products; and tooling and workholding.
Once I enter the pavilions, I stand in awe of how large the show truly is—about 1.3 million sq. ft. of technology. For those who have not attended IMTS, that’s considerably larger than other U.S. manufacturing trade shows, which typically have around 500 vendors and last only 3 days.
When I go to IMTS, I usually attend for 2 days and target two pavilions: the one that focuses on metalcutting equipment, and the one for cutting tools and workholders. The metalcutting pavilion usually consumes the better part of my first day because there is just so much to see and so many people to talk to.
On the second day, I’ll hit the pavilion for the tooling and workholding products. There’s always something new there. Then, I will visit the Industrial Automation North America co-located show, which is being held for the third time at IMTS. I always enjoy checking out the robots and automation systems. And, if time allows, I’ll visit the QA pavilion and see the additive-manufacturing equipment. I am not involved with AM, but I like the technology and what it can offer.
Let’s not forget the show also offers nine conferences, more than a dozen exhibitor workshops and training activities.
In addition, there’s the Smartforce Student Summit. Registration is free for students and educators.
If you’re going to attend IMTS, just remember to wear the most comfortable shoes you have. If you don’t have a suitable pair, get a pair. And keep hydrated. I’m always surprised at how much this show takes out of me. So, make your wish list and check it twice. Maybe I’ll see you there.
  • abrasive
    abrasive
  • abrasive machining
    abrasive machining
    Various grinding, honing, lapping and polishing operations that utilize abrasive particles to impart new shapes, improve finishes and part stock by removing metal or other material.
  • metalcutting ( material cutting)
  • sawing
    sawing
Author
Machinist's Corner Columnist
Michael Deren is a manufacturing engineer/project manager and a regular CTE contributor. He can be reached via e-mail at [email protected].
