Milling fixture tips
Author Brandt Taylor
September 18, 2020 - 01:30pm
In this article, I’ll show a method to make a modular fixture for mill applications. The fixture uses an off-the-shelf mechanical clamp and a novel work stop.
Holding parts for machining on a milling machine can be challenging. For our purposes here, the problem is machining a long, skinny part. It is a tool steel machine knife that must have an array of countersunk holes installed. The part has dimensions of 4.75 mm by 19.05 mm by 469.9 mm (0.187"×0.75"×18.5"). Marks on the edges of the part are not allowed. The batch has 50 parts to process, so quick part change is in order. Figure 1 shows the fixture and the part unmounted. Figure 2 shows the part mounted on the fixture. Figure 3 shows details of the fixture hardware.
Figure 1: Shown are the fixture and the part unmounted. Image courtesy B. Taylor
Figure 2: The part is mounted on the fixture. Image courtesy B. Taylor
Figure 3: Details of the fixture hardware are displayed. Image courtey of B. Taylor
The fixture base is 38.1 mm by 127 mm (1.5"×5") aluminum bar stock that is 533.4 mm (21") long. The top and bottom faces of the bar stock are finished flat and parallel. The bottom face has two T-slot keys installed that fit into a T-slot on the milling machine table. Two counterbored holes are provided on the top face of the fixture to accept T-slot clamping nuts. One of the counterbores is finished with a boring bar so that hole can be used as an index when installing the fixture on the machine. The two T-slot keys and two T-slot clamping nuts all use the same T-slot on the milling machine table.
The fixture uses an array of five hex head pins and five edge clamps to hold the part being machined. One round dowel pin at the end of the part sets the length dimension.  The hex pins are made from 12.7 mm (0.5") steel hex stock turned to 12.7 mm/12.675 mm (0.5"/0.499") dia. on one end. They fit into 12.725 mm (0.501") dia. reamed holes on the fixture. (See Figure 3.) The hex head pins are free to turn in the holes. This ensures that the part is clamped squarely against a hex face and there is an adequate clamping surface against the part. Using this method, marks are not made on the part edge. If round dowels were used, they would make a mess of the knife edge.
The clamps are fixture clamps by Mitee-Bite Products LLC in Center Ossipee, New Hampshire. These clamps have a brass nut mounted on a steel threaded bolt and are available in a variety of sizes. In this application, the size with 3/8"-16 thread is used. The clamps have an eccentric arrangement, so when the bolt is turned with a hex wrench, the nut moves radially on the bolt, clamping or unclamping the part. They are quick and easy to use.
This type of fixture using edge clamps and hex head pins has the advantage of positively locating horizontal dimensions. This way also can be used to clamp round or irregularly shaped parts with accuracy and repeatability. For a round part, using four clamping points works well. Use two hex pins to set X and Y position and two edge clamps to push the part against the hex pins. One hex pin at 0° and another at 90° and one edge clamp at 180° and another at 270° will do it. I hope that this helps.
  • boring
    boring
  • boring bar
    boring bar
    Essentially a cantilever beam that holds one or more cutting tools in position during a boring operation. Can be held stationary and moved axially while the workpiece revolves around it, or revolved and moved axially while the workpiece is held stationary, or a combination of these actions. Installed on milling, drilling and boring machines, as well as lathes and machining centers.
  • fixture
    fixture
  • flat ( screw flat)
    flat ( screw flat)
  • gang cutting ( milling)
  • milling
  • milling machine ( mill)
  • milling machine ( mill)2
  • parallel
    parallel
