Joining flexibility with high productivity when gear milling.
Imagine a gear milling method where the toolpath—not the tool shape—determines gear characteristics such as diametral pitch or pressure angle. A new concept, involute milling, provides that functionality while delivering machining efficiency and production versatility. The result is a “democratization” of gear milling, moving the process from single-purpose, dedicated machine tools to multipurpose machines that can produce small batches economically because no costly hobs or gashers are needed.
All images courtesy Sandvik Coromant
Involute milling, or InvoMilling, uses standard mill/turn machines and off-the-shelf cutting tools to produce small to medium-sized batches of spur and helical gears.
Gear making typically involves custom orders. Said one manager at a gear milling company: “We specialize in helical and spur gear wheels for a range of different industries, with many machined to specific customer requirements. A customer may want a specific gear wheel, batch of gear wheels or components for automobile transmissions. We mostly produce from one to 100 components, but we also have production orders for up to 2,000 gear wheels throughout a year. Just-in-time deliveries are the norm for some products, particularly when it comes to components for vehicle gearboxes.”
Until recently, this type of production scenario meant the gear maker would have to lock into using special, one-off gear-making tools for each project to produce high volumes. However, creating new tooling and programming for each gear wheel is costly.
Outside the Box
The new gear milling approach is based on using a multiaxis mill/turn machine. Sandvik Coromant Co. developed involute milling and it is being offered in collaboration with DMG / Mori Seiki USA Inc. Involute milling, or InvoMilling, is an alternative to the specialized hobbing process traditionally used to make gears. For gears with 25 to 30 teeth, InvoMilling’s cycle time is comparable to single-start hobbing with HSS tools. However, the possibility to integrate many operations in one setup and on one machine can reduce overall cycle times. Also, the wait time for a new gear hob can be weeks, while acquiring a new CNC InvoMilling code takes a matter of hours.
In this multiaxis gear-milling process, multipurpose machines are fitted with tools composed of off-the-shelf inserts for making spur and helical gears. It can produce spur and helical gears using a disc-shaped milling cutter tooled with grooving inserts. With simultaneous motion of the X and B axes or the Y and B axes, the tool follows an involute path. Consequently, variations in gear shape are produced according to the toolpath—not the shape of the tool. For this purpose, mill/turn machines are ideal.
When involute milling the tooth space of an outer spur gear, a groove is facemilled in an axial direction on the workpiece. For the following cuts, the gear wheel rotates slightly, coordinating with the simultaneous radial plunging of the InvoMilling tool, creating an involute curve shape.
It is now possible to program in the MORI-AP conversational software for InvoMillng processes, which is available for DMG / Mori Seiki Model NT mill/turn centers. The flexible B-axis with ±120° rotation range, the high speed and precision of the direct-drive motor and the indexing capability of 0.0001° allows production of gears with up to a DIN 6 quality.
Gear hobbing has traditionally been performed on a dedicated machine, which also can produce other transmission components. However, due to its lack of flexibility, hobbing is not the optimal solution when many different types or small batches of gear wheels need to be produced.
InvoMilling is a combination of slot milling and turn milling. It enables machining of gears of any helix angle—both involute and noninvolute profiles—with the same tools. This series illustrates the process.
Step 1: slot milling.
Steps 2 and 3: machining the root and protuberance.
Step 4: turn milling the lower gear tooth profile.
Step 5: turn milling the upper gear tooth profile.
Step 6: finished tooth space.
InvoMilling software for the NT machine immediately enables manufacturing different types of gear wheels. Gear-making cutter kits with three tools—CoroMill 161, Coro-Mill 162 size 4 and CoroMill 162 size 6—cover the range from module 2 to 12, or 12 to 2 DP (diametral pitch).
The price of a kit is similar to that of one dedicated inserted hob. The kit can be used to produce a range of modules, while the hob can only produce one single module, albeit more quickly.
Involute milling is a combination of slot milling and turn milling. It machines gears with any helix angle—both involute and noninvolute profiles—with the same tools. The number of cuts involved depends on the size of the gear and the size of the cutters being applied.
This method makes use of the advanced machine control and high accuracy of the NT mill/turn machine and the cutters to make finished gears on the machine as well as semifinished gears to be ground on a separate machine. Applying the latest developments in insert grades has also enabled a high level of cutting data to be applied for optimal efficiency.
In addition, chamfers at the gear tooth’s OD can be machined during involute milling, as well as protuberance angles, profiles and radii at the tooth’s base. The cutting forces with this process are considerably smaller than with hobbing, so larger tooth forms can be made in smaller machines.
For example, when involute milling the tooth space of an outer spur gear, a groove is milled in the axial direction on the workpiece. In the following cuts, the gear wheel rotates slightly, coordinating with the simultaneous radial plunging of the cutting tool, producing an involute curve shape. For larger gear modules, more cuts may be necessary. For wider gears, the cutter is offset in the axial direction and the procedure is repeated.
Involute milling can produce spur and helical gears using dedicated milling cutters, such as CoroMill 161 (top) and two sizes of CoroMill 162 (above), which together cover modules 2 to 12.
Involute milling offers several key advantages. Because each cutting tool covers several gear modules, overall tool costs for small to medium-sized batches are lower than comparable hobbing processes. Also, lead time is not an issue, while hobbing tool lead times can be 8 to 12 weeks.
One disadvantage of involute milling is that it is somewhat limited for larger gear modules, but the process has been used to produce up to and including a module 18 gear wheel with a diameter of 800mm.
Another manufacturing process used to make gears, endmilling, is flexible but slow. Involute milling combines the speed of disc cutting with the flexibility of endmilling, and, all things considered, can be up to 10 times faster than using endmills for gear manufacturing.
Indexable Inserts
Modern indexable-insert technology makes this new gear milling method possible because the positive geometry on each insert generates low cutting forces, enabling a high level of cutting data to be used while ensuring accurate profiles for close tolerance ranges. With involute milling, gear teeth with quality level 6, DIN 3962 or better can be achieved. Moreover, surface finishes finer than 3µm Rz can be achieved through the correct application of tools in sufficiently rigid machines.
In addition to producing gears to quality levels comparable to hobbing, involute milling can generate various gear grinding allowances. That is to say, material can be left on the gear flanks that can then be ground away to obtain gears with very accurate shape and surface finish.
Cycle time for involute milling gear modules 4 to 10 is, when the number of teeth is below 30, comparable to single-start hobbing with HSS tools. Because many operations can be integrated in the multitask machine, the gear can often be finished in one setup. This results in short lead times and changeovers, and, consequently, improved work-in-progress levels for production of one-offs and small and medium-sized batches.
Due to these efficiencies, even in cases where the cycle time for involute milling is longer than for hobbing, total manufacturing time is shorter. Because there is no waiting time for a dedicated tool to be made, production can start immediately after a new setup is completed.
Involute milling represents a real technology shift, providing significant improvements in cost, flexibility and lead time while using advanced multitask machine tools to manufacture high-quality gears. CTE
About the Author: Aaron Habeck is marketing project manager for Sandvik Coromant Co., Fair Lawn, N.J. For more information about the company’s InvoMilling process, call (800) SANDVIK or visit www.sandvik.coromant.com/us.
- centers
centers
- endmilling
endmilling
Operation in which the cutter is mounted on the machine’s spindle rather than on an arbor. Commonly associated with facing operations on a milling machine.
- grinding
- grooving
grooving
- high-speed steels ( HSS)
- just-in-time ( JIT)
just-in-time ( JIT)
Philosophy based on identifying, then removing, impediments to productivity. Applies to machining processes, inventory control, rejects, changeover time and other elements affecting production.
- milling cutter
milling cutter
- outer diameter ( OD)
- pitch
pitch
- tolerance
tolerance
