OMAX Corp. expands its GlobalMAX pump options with a 10-hp pump for the GlobalMAX JetMachining Centers. Designed for educators, job shops, fabricators and manufacturers who need an economical, industrial abrasive waterjet, this new pump delivers 30,000-psi pressure to the cutting nozzle. The GlobalMAX product line with the 1-hp pump offers all the benefits customers come to expect from OMAX: innovative drive systems, direct-drive pump technology, Intelli-MAX software and superior customer service.
The combination GlobalMAX with the 10-hp pump is priced as low as the mid $50,000s USD – or under $1,000 USD per month financed. Owners are able to upgrade to a larger horsepower pump if their needs outgrow the 10-hp unit.
The GlobalMAX JetMachining Centers can cut almost any material in any thickness up to 5 in. (0.125 m) without any heat-affected zone (HAZ). A number of compatible accessories are available including a terrain follower, a pneumatic drill and a bulk garnet feed hopper.
- abrasive
abrasive
- abrasive waterjet ( AWJ)
System that uses high-pressure waterjets in combination with a slurry of fine abrasive grains to machine materials. See waterjet cutting.
- centers
centers
- feed
- heat-affected zone
heat-affected zone
That portion of the base metal that was not melted during brazing, cutting or welding, but whose microstructure and mechanical properties were altered by the heat.
