14-inch Gear Head Milling Machine
The gear head machine a highly precise, powerful and versatile option. It is ideal for milling, drilling, slotting, engraving, boring, tapping and angle machining operations. The all-gear drive transmission delivers full power at any speed. A high-performance brushless DC motor with permanent current control is standard.
The 14-inch Gear Head Milling Machine from Palmgren can handle a wide range of machining operations that would normally be performed by larger and more expensive machines. This makes the gear head machine a highly precise, powerful and versatile option. It is ideal for milling, drilling, slotting, engraving, boring, tapping and angle machining operations. The all-gear drive transmission delivers full power at any speed. A high-performance brushless DC motor with permanent current control is standard.
The #9680164 highly versatile14-inch Gear Head Milling Machine from Palmgren is the right option for tool rooms, pattern shops, mold and die shops, job shops, fabrication shops and maintenance departments.
