80X Series JetMachining Centers
OMAX offers the versatile 80X with Tilt-A-Jet taper-compensation technology. OMAX Corp.s 80X Series JetMachining Centers incorporate multiple table sizes and a customizable work envelope for precise abrasive waterjet cutting of large components and multiple-part projects.
September 19, 2018
The Tilt-A-Jet's advanced automated taper compensation attains virtually zero taper for the precision cutting of parts with square, taper-free edges, including interlocking pieces and dovetail fittings, all while maintaining extremely high cutting rates. With the water-resistant Rotary Axis head for complex 3D parts production, the 80X's capabilities expand to cut in as many as 6 axes.
With the specially designed Intelli-MAX Software Suite and elite EnduroMAX pump technology, 80X machines swiftly and accurately cut a wide range of materials and thicknesses from metals to advanced composites to glass. The user-friendly software makes it easy to go from concept to finished part in minutes. OMAX's EnduroMAX pump is designed for long life with a capable of up to 1,000 hours between pump rebuilds, maximizing machine uptime.
  • waterjet cutting
    Fine, high-pressure (up to 50,000 psi or greater), high-velocity jet of water directed by a small nozzle to cut material. Velocity of the stream can exceed twice the speed of sound…
  • work envelope
