Alumigator ASR-5 End Mill
5 Flute High Performance Carbide End Mill
Introducing the Alumigator™ ASR-5 end mill, a 5 flute high performance carbide end mill for high speed roughing in Aluminum available in both coolant-through and solid configurations.
This revolutionary new end mill boasts an unequal indexing configuration that reduces chatter for the optimized high efficiency milling of Aluminum Alloys. Designed and engineered from the Alumigator family of high performance aluminum mills, the 5 flute configuration with polished flutes can achieve metal removal rates in excess off 100 cubic inches per minute. Staggered roughing serrations and proprietary gashing geometry ensure small chip size to enable more aggressive feed rates and depths of cut.
Be it roughing, finishing, pocketing or profiling, the Alumigator™ Super Rougher (ASR-5) end mill for ultra high speed roughing is designed to devour aluminum alloys and other non-ferrous materials. Contact GWS today to get one and put it to the test.
  • alloys
    alloys
  • aluminum alloys
    aluminum alloys
    Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wrought compositions and casting compositions. Some compositions may contain up to 10 alloying elements, but only one or two are the main alloying elements, such as copper, manganese, silicon, magnesium, zinc or tin.
  • chatter
    chatter
  • feed
  • flutes
    flutes
  • gang cutting ( milling)
  • inches per minute ( ipm)
  • milling
  • milling machine ( mill)
  • profiling
    profiling
