AM Type Insert
AM Type Insert
The new AM Type insert is designed for non-ferrous metal machining, featuring a sharp cutting edge achieved through ground peripheral surface and polished rake face to a mirror-like finish. This design reduces built-up edge during machining and ensures a high-quality, glossy surface finish. The insert grade "KS05F" is a fine-grained carbide that balances wear resistance and chipping resistance, providing exceptional reliability and stable performance across a wide range of applications.
September 3, 2024
Tungaloy Corporation (President: Satoshi Kinoshita, Headquarters: Iwaki City, Fukushima Prefecture) announces the addition of the "AM Type" insert for non-ferrous metal machining to its center blade multi-functional cutter "DoMultiRec".
Overview
"DoMultiRec" is a multi-functional milling cutter with a center cutting edge capable of a wide range of operations, from drilling and shoulder milling to pocket / cavity milling. By optimizing the arrangement of the inserts, the front cutting edge becomes almost flat, achieving a high flatness on the bottom during drilling, making it ideal for counterboring operations. Additionally, the inserts can be used for both center and peripheral cutting edges, with two cutting edges for center cutting and two for peripheral cutting, allowing a total of four corners per insert, making it highly economical.
The new "AM Type" insert is designed for non-ferrous metal machining, featuring a sharp cutting edge achieved through ground peripheral surface and polished rake face to a mirror-like finish. This design reduces built-up edge during machining and ensures a high-quality, glossy surface finish. The insert grade "KS05F" is a fine-grained carbide that balances wear resistance and chipping resistance, providing exceptional reliability and stable performance across a wide range of applications.
The addition of the "AM Type" insert to the "DoMultiRec" series will greatly contribute to tool consolidation and productivity improvement for a wider range of industries.
  • wear resistance
  • milling cutter
  • counterboring
    Enlarging one end of a drilled hole. The enlarged hole, which is concentric with the original hole, is flat on the bottom. Counterboring is used primarily to set bolt heads and nut…
