Basic Mill Solid-Carbide Endmills
HAIMER introduces their newest line of endmills, the Basic Mill. The Basic Mill is all the quality you would expect from a Haimer endmill – reduced to the essentials. Basic Mill solid-carbide endmills are created with H6 shank tolerances using cutting edge geometries with an unequal flute and helix design, which reduces vibration while machining.
February 17, 2017
HAIMER introduces their newest line of endmills, the Basic Mill. The Basic Mill is all the quality you would expect from a Haimer endmill – reduced to the essentials. Basic Mill solid-carbide endmills are created with H6 shank tolerances using cutting edge geometries with an unequal flute and helix design, which reduces vibration while machining. The basic mill can be used in almost all material, including stainless steel, alloy steel, cast iron, aluminum and general steels.
Despite the name, performance is anything but basic, as the endmill is capable of aggressive roughing machining strategies that include slotting, trochoidal milling, steep ramping and even plunging. Available in inch and metric, a full complement of radii and flute lengths, and with or without Safe-Lock shanks, the Basic Mill series is the do-it-all endmill for the shop.
