Brother M140X1 Multitask Machine
The Brother M140X1 from Yamazen works best in mass-production parts processing. This compact, multitasking machine has an added turning function in conjunction with Brother's high-speed mill and tapping.
October 13, 2013
Workpieces previously machined using a turning center and a machining center are now combined into one machine, thereby reducing handling time between machines. The newly developed high-speed and high-output built-in DD motor produce more efficient turning with a maximum speed at 2,000 rpm.
The M140X1's integration of the turning and milling process contribute to high-efficiency machining and bring both time and financial saving advantages.
  • machining center
