C-Cutter Mini
C-Cutter Mini
BIG KAISER Precision Tooling Inc. says the C-Cutter Mini enables milling at an ultrahigh feed rate. It offers a small cutting diameter and features a compact design that accepts four inserts, including ones as small as 0.197".
August 25, 2016
BIG KAISER Precision Tooling Inc. says the C-Cutter Mini enables milling at an ultrahigh feed rate. It offers a small cutting diameter and features a compact design that accepts four inserts, including ones as small as 0.197". The high-performance chamfer cutter achieves an ultrahigh feed rate by reducing the cutting diameter to the lowest limit. The tool is suitable for chamfering, back chamfering and facemilling.
Customers who purchase inserts for the C-Cutter Mini receive a free tool body for any diameter, with a limit of one body per customer.
  • facemilling
  • chamfering
