C-HOG MILLHOG O.D. Clamping End Prep Tool
An OD clamping portable beveling tool that is ideal for performing end preps on thin-wall tube where maintaining the integrity of the ID is critical has been introduced by Esco Tool.
The C-HOG MILLHOG O.D. Clamping End Prep Tool evenly distributes holding power to securely mount on the outside of high purity thin-wall tube and perform chatter-free welding end preps. Maintaining the integrity of the inside of the tube, it can produce any angle of prep including j-preps without needing cutting fluids and is suitable for orbital welding.
Capable of prepping and flat-facing simultaneously, the C-HOG MILLHOG O.D. Clamping End Prep Tool is suited for tube and pipe from 0.50" ID to 3.0" OD and is offered with pneumatic, electric and battery power. Equipped with a ratchet feed, it provides over 1" of stroke for smooth operation.
