Combination Bench Lathe and Mill
The 11-inch bench engine lathe and gear head mill is able to handle a wide range of turning, milling and drilling operations typically found on much larger machinery. Constructed from heavy cast iron, its smooth power transmission with precision thrust and ball bearings in the head stock and spindles are designed to provide years of trouble-free operation.
Palmgren's all-purpose Combination Bench Lathe and Mill delivers the precision, power and versatility of larger machines.
The 11-inch bench engine lathe and gear head mill is able to handle a wide range of turning, milling and drilling operations typically found on much larger machinery. Constructed from heavy cast iron, its smooth power transmission with precision thrust and ball bearings in the head stock and spindles are designed to provide years of trouble-free operation. Its versatility and features make it one of the most functional and efficient machine centers for all types and sizes of shops.
