Eltool Corp.'s compact angle head can mill and drill in bores or cavities down to 5⁄8" in diameter. Machining center versions are powered by the machines high pressure coolant system, not spindle rotation, allowing multiposition machining with one head.
Available in all popular shank styles, the head loads easily from the ATC with no stop block. Live Lathe models allow secondary ID milling and grooving operations to be integrated into turning operations. VDI, BMT and other versions are offered for both face and OD mount turrets.
- coolant
- grooving
grooving
- inner diameter ( ID)
- lathe
lathe
- machining center
machining center
- milling machine ( mill)
- outer diameter ( OD)
- shank
shank
- turning
